Longfisher
- Jun 23, 2008
- 11
Have a Merc 200 HP Offshore (1998) which sat idle last year (sunk all my money into a trailer rebuild). Stored it as usual. Started it every week or so.
Started fine this season but pee stream seemed weak while on hose recirculator and at idle or near idle.
Took it to the lake for shake down before going offshore and am glad I did. Motor ran fine at marina while in no wake zone and tell-tale had water coming out of it but, again, less than I'd seen in years past.
Put boat on plane after traveling only about 300 meters and noticed no water from tell-tale. Throttled down and then heard overheating alarm. Shut it off for 30 minutes while the kids swam around the boat to let it cool off.
Restarted it and after warming up for a couple of minutes the water came out of the tell-tale, again a little less strongly than I've seen in the past. Idled fine and even took a load at idle or just above idle without problem. Motored back towards the marina.
About halfway back towards marina pee stream became strong again so turned around and increased rpms to put it on plane. Pee stream stopped and engine overheat alarm came on pretty quickly after that. Neutral but then heard detonations so shut it off completely and let it sit for 20 minutes to cool off.
Started it again and pee stream was again weak. Motored back to marina and retrieved boat to trailer and came home. Wasted trip but glad to find problems before running offhsore.
OK, so what's the problem with this outboard given my description? Spun impeller? T-stats (not likely as pee-stream not apparent as motor warming up and then apparent after motor comes up to temperature)? Poppet valve? Obstruction?
Any help is much appreciated.
LongFisher
LongFisher
