Hi,
My 15 HP is runs fine at full throttle for several seconds (couple minutes) and then beings sputtering. To fix the problem, I simply continuously squeeze the ball on the fuel line to the engine and the engine begins to run fine again for as long as keep squeezing it. I assume this is some sort of fuel system problem. Can anyone advise me as to where i should start fixing this problem?!? Thanks in advance.
Jim
Jim
