Wakeboard fins
Geo2008
Banned
My new wakeboard came with two fins that I can mount on the bottom, Whats the deal with these fins?
Should I try it with or without the bottom fins that mount on the bow and stern of my wakeboard?
What is the significance of these fins?
It seems like it would make a 360 more difficult.
All advice appreciated...
amynbill
Re: Wakeboard fins
GOing by your other post where you cant even get up yet...you are a long way from a 360 ;)
The fins give support while carving/edging. It helps maintain the board's tracking through the water with less slippage. I suggest keeping them on until you learn to edge in all positions.
Once you master edging, you will most likely learn toeside to heelside 180, in which you can still keep the fins on, and even on more advanced tricks the fins wont get in the way.
They are removable of course as some more advance riders feel they do get in the way. My old board had a fin, and I was still able to 360+and it was fine...some riders feel it "locks" down the landing too much.
Geo2008
Banned
Re: Wakeboard fins
Next trip I will be armed with the necessary knowledge and will get up or drown trying, Failure is not an option.:eek:
Thanks for the excellent advice.
amynbill
Re: Wakeboard fins
I think you will get up:)
Keep trying, really. It WILL happen, and you will then be ready for the next stage...staying up! Dont rush if you want to continue in the sport...learn each stage correctly. I highly recommend "the book" dvd series. It defines the perfect learning stages and helps you build up to tricks.
Realistically, it should take a full season (depending of course how often you go out and session) to get up, learn the riding positions and edging positions, wake to wake jumping and finally 180's and switchfoot.
Once you have those under your belt, learning anything else is simply building on those basics which can be learned and practiced on a trampoline. Even flips and 360+ are just built on the basics you can master in your first season.
Geo2008
Banned
Re: z郑州网智信息技术有限公司
Re: z郑州网智信息技术有限公司
科学技术是第一生产力,透光云石信息化进步是中国电子商务革命的最重要组成部分,透光云石作为电子商务系统建设领域的专业服务商,透光云石网智愿意积极承担应有的行业责任,始终专注用户实际效益,透光云石始终专注产品先进性,透光云石致力提高中国电子商务生产力
You took the words right out of my mouth:)
