94 force 90hp leaking oil
trophyforce
just traded my 1989 aquasport 175 center console for a 1994 trophy with a 1994 90 hp force. motor runs awsome it has been rebuilt 1 year ago. my question is : i run the motor in a 55 gallon drum because the muffs dont fit to good over the water intake , after flushing the salt from the motor and empting the barrel i notice dark brown oil leaking from the small middle holes under the cavitation plate. it is just a little stream of oil on both sides is this normal??is it from the exhaust? drained the lower unit oil , its new and green in color, no water. are those 3 holes on each side of the lower supposed pee water while running?it pees water out the exhaust like crazy witch is good. any info would be great . this force runs better than any motor i have ever owned , it sat for a week and started on the second crank . AWSOME!!
thanks
jerryjerry05
Re: 94 force 90hp leaking oil
Thats probably just unburned fuel.It has way of leaking down.
The water is from water that gets in while in the barrel and just finding it's way out.Jerry
trophyforce
so those 6 small holes are just for drainage? is there any thing else i should know about these motors? thank you for the quick response.
