2005 Chaparral 260 Sig with VP 8.1... fuel system ?'s
Gravity
I'm curious if anyone knows off of the top of their heads if an '05 Volvo Penta 8.1L EFI has a RETURN fuel line going (looping) back to the tank, from the injector rails. Or if the fuel line terminates at the injectors. I ask this because I'm interested in installing a fuel flow/volume transducer. It will only work on engines that only have a supply line, and not models with an actual LOOP. Any and all info would be greatly appreciated. -MV
Don S
Re: 2005 Chaparral 260 Sig with VP 8.1... fuel system ?'s
No return to the tank, on any Volvo engines.
JustJason
should be a return line to the vst if im not mistaken
Don S
That doesn't create a problem for his fuel sensor, only a return line to the tank would cause problems.
Gravity
AWESOME! Thank you very much!!
-MV
