how do i fix this
rdnk_4_lf
Re: how do i fix this
we are buying the 73 merc it is really nice the only thing is it wont open up can anyone help in this section i posted one on the merc forum to
F_R
I'm sure the Evinrude people will be happy to see you made the switch. Now give the Merc people a bad name.
samo_ott
I don't know how to say this any other way - it isn't the johnnyrudes that you are having problems with, it is your lack of understanding of how an outboard motor works. If you bought an OMC motor that was abused or simply in need of long overdue maintenance, you will do the same with any other brand and you will have the same problems.
I have a pair of 50 year old Evinrude Big Twins and they are still perfectly serviceable motors. I also own a 36 year old Johnson and a 39 year old Johnson (main engine & kicker), which are on my boat now, and they are very dependable.
As for the JB Weld, its a handy product for a limited range of things. Fixing a crankshaft or a flywheel is not one of them. Do yourself a favor and put the stuff away before you hurt someone.
Sorry if this sounds strong but, you need to hear it as it is - trying to fix the components that you speak of with an epoxy product is both irresponsible and dangerous.
I concur with Jay.
rdnk_4_lf
i am not saying that they are trash the 50 rude is probably the best motor ive ever owned i just have had really bad luck with them two in the last three years how good are the new e-tecs the next boat i buy i might get 1 i just need some expert advice
freddyray21
all motor manufacturers I am sure have had some lemons, but again all of them have to be maintained correctly for them to last. I am running a 1957 35 hp on one of my boats. Over Memorial day weekend it was the only boat that did not have an issue of some type and it towed two other boats in.
rdnk_4_lf
well i really want to thank all of you guys that have give me your time and advice i have laid down the j+b weld for use on an outboard thanks to you guys and due to your advice that motor is on a rack out in the garage we bought a merc and the previous owner sprayed starting fluid into the top carb and messed up the rings now we are taking it and having it fixed right once again thanks for your help nick
