35 hp and 40 hp starters the same ?
Mic1227
Hi Guys,
Was wondering if anyone can tell me if the starters are the same for a 35 hp Johnson and a 40 hp Johnson ? I have a 58 35 hp and need a starter and a ignition switch if anyone has one to sell. Thank you !
Mike
Edit: email addys, not allowed. for your protection, use the PM system. TD
jay_merrill
Re: 35 hp and 40 hp starters the same ?
The answer to that question is yes and no. Generally speaking, the starters for the late fifties 35hp motors and the later (60s) 40hp motors are the same. This is also true of the starters for the 28hp model and the 33hp model.
What you may see, however, is that some of the older ones had only two brushes in them. You can tell the difference between the two by the length of the starter and the number of screwheads in the sides - two for two brush and four in the four brush model. Either one should work.
F_R
They are more or less the same--sort of. However the length varies and requires different support brackets on the bottom end. The shortest ones didn't even have support brackets. Nor were they as powerful.
rdnk_4_lf
well we took a 125 johnson starter and put it on a 50 evinrude so i imagine it will work
