How do I seal an outdrive?
Status
Not open for further replies.
Wvawitrado
Just bought a 1973 cobalt has a small leak nothing major but wanted to re seal the outdrive.....no clue any help would be more than appreciated THANK YOU!!!!
Haut Medoc
Re: How do I seal an outdrive?
Depends on where the leak is, some are easy, some require complete diassembly......;)​
Wvawitrado
I don't think the leak is coming from the out drive i screwed a screw through the bottom BONE HEAD!!! FIRST TIME BOAT OWNER!!! Either way i wanted to re seal it how goes it?
ziggy
ya can pressure test the drive to see which seal is leaking. if any. empty the fluid out of the drive. note that it's not milky. milky is water intrusion and a leak. feel the fluid on the way out. specially the first part right after ya take the drain screw out. feel for metal fragments..... none is good....
after it's empty. fill hole screw in place. make something like this to pressure test it @ 15psi. it should hold all day. if not. remove drive and repressure test and use a spray bottle with soapy water to help locate the leak....
that pic is of a bike tire pump. a t to connect a pressure gage too and a mercruiser gear lub end to fill the gear lub up with, modded for my pressure tester... connection to the tire pump is a tire valve stem ground down to fit....
the white this is a auto break self bleeder. a vacum pump. yer drive should hold around 5-7hg of vac.....
if it holds pressure and vacuum, yer ok and don't need to reseal it....
ya will absolutly need a service manual too. oem is best.... ya need #1....
http://forums.iboats.com/showthread.php?t=251571
check engine s/n and drive s/n against service manual to confirm it's the proper maunaul... service manual #1 is a real large pdf file. 1.23 gb. so give it time to download.....
Wvawitrado
Wow thank you very much for you helpful insight I will try that tonight
Bt Doctur
Using new seals,of course.
but for the correct information you need to tell us what type of drive it is.
bamadave
Are you saying you put a screw in the bottom of the boat, and you need to seal it?
ziggy
Haut Medoc
Hmmmmm, you screwed a screw through the bottom of your boat & it's leaking & I'm the bone head?......
You can't word a question correctly & I'm the bone head?....:rolleyes:
I think not!
Next time, think before you say something stupid.....;)
Ayuh,....
If you're trying to seal a hole in the bottom of the Boat,..??
Then just Why is this thread titled "How do I seal an outdrive?"
I agree with Haut,....
You have to be Very Clear with your Questions....
Don S
Digging up bones Haut ????????
Ayuh,... Must Be,... Haut got me Good with this Old 1....
Haut Medoc
I was looking for a pic of ziggy's home made pressure tester, when I saw the OP's reply to me.....
I felt he deserved more 'input'......:D
Fishermark
It's funny Haut - when I read that I read it as the poster calling HIMSELF a bonehead after he had discovered what he did... but with a lack of reply, I guess we'll never know! ;)
Status
