Installing New Stator and Trigger Question
Myke48
1985 mercury 75H.P. Do I need to retime the engine and is there anything else I have to do after installing new stator and trigger.
Laddies
Banned
Re: Installing New Stator and Trigger Question
It should start right up but it's a good idea to check the timing after replacing the trigger.
gregpro50
Definitely check the timing. I just changed the trigger and stator in mine and didnt check the timing. It seems that the timing got advanced after I did the change and I didnt check the timing afterwards. The result was a melted piston and I am now changing the powerhead....
Myke48
I just got back from west marine and the book they have on it makes timing the engine harder than the actual installing of the stator and trigger~!
Myke48
I am thinking of installing the stator and trigger and let the mech. do the timing.
j_martin
Do a link n sync by the manual. You'll learn a lot about your motor.
John
Myke48
Linc n Sync do I need a large water tank for that or is that a dry procedure ?
That is why I would like to do it myself,,just not for $$ saving but to learn about my engine.
Thanks,,Mike
j_martin
All the setup and timing is done with the starter motor. Final idle setting is done at the lake.
It's in the book.
John
Myke48
What is the name of the book you are refering to?
thanks,,Mike
j_martin
The genuine Mercury Maintenance Manual for that engine.
gregpro50
Setting the timing itself is pretty easy. The only thing that intimidated me was setting the actual timing pointer.
Myke48
Thanks J Martin,,
Greg,,,Yes it looks very intimidating but I think I am going to try doing it myself for the knowledge.
I am going to go see if I can find an original merc manual tomorrow at the merc dealer.
Thanks,,,Mike
Myke48
the timing Pointer?? Someone please explain this pointer thing,,,,,
Thanks,,Mike
gregpro50
Check to see if your timing pointer is adjustible. Some were but I'm not sure on your year. Maybe someone else can chime in. If it is you need a dial indicator to make sure the marks on the flywheel really indicate where the engine is in relation to it. Mine happened to be off a few degrees which would have affected the final timing.
j_martin
3 degrees timing on an 85 merc with today's gas is the difference between running right and turning into scrap before you get across the lake.
hope it helps
John
gregpro50
hope it helps
John
That is exactly why I am now changing my powerhead due to a melted piston from improper timing.
Myke48
That is what is intimidating to me,melted pistons,,bigger problems than the original one,,I still want to do it ,so you will be seeing me asking questions as I go along.
You guys have helped and have given me confidence to do this,just want to thank you all,,,,Mike
