This is a original Bayliner Capri controller on 1985 year boat. While inspecting and cleaning all connections i moved the screw barrel assembly connecting the cable too much in one direction. It sits behind the controller. Now the shifter has Neutral in about the 10 O'clock position instead of the 12 noon position. I need a description of how this control works, how it adjusts before I work on it to get it back to where it was. The other difference i noticed is that the WOT RPMs are higher now with it adjusted out like that which can't be good! I would just adjust it the other way but cannot remember how I moved it the first time....ARGGH!
Joe
Joe
