willawalla
Thread starter- Joined
- May 7, 2007
- 14
I bought an old 19' Bayliner with this engine and outdrive with the knowledge that the engine did not turn. I found out that it would turn after oiling the cylinders. Then I found that the oil was frothy (like it was mixed with water). Does that necessarily mean a blown head gasket? Would a compression check verify if it is? If so, does anybody have any tips on replacing the head gasket? Is it straight-forward and easy like replacing the gasket on a Chevy, or is it trickier? Any tips or help would be greatly appreciated.
Also, are there any concurrent problems with this engine/outdrive model? Any idea on how the boat will perform with this set?
Thank you to anybody who'll respond!
-Jeff
-Jeff
