Re: '84 70 HP Johnson Fast Idle
Thanks for all the input from those who tried to help. I decided to go ahead and put the houseboat in the water to really see what would happen to the RPM's. The motor is still idling at 1100 to 1200 RPM's, but when I put the motor in gear it goes down to 850 to 900 RPM's. The shifting in gear sounds ok, no heavy "klunking". The motor ran well on up to 5000 RPM's. It seems to run best about 3000 RPM's. My mechanic has not returned, since he did the link and sinc. I have another mechanic that said he would look at it this weekend. The idle adjust screw is not even touching, so I don't think that is a factor. Again thanks for all the help. I can do simple things on an engine, but this problem has "stumped" me. HTY
