Got a 88 year johnson I need to put a water pump in, I know it has been at least 2 years since it has been done. Just recently bought the boat, and the tell-tale was going strong. Since then it has diminished to just trickling out, so think its time for a new impeller before I tear something up. So I went about unbolting the lower unit, and went to disconnect the shifting linkage, only to find that the bolt that goes through the linkage directly under the motor itself appears to have a broken head on it. At first I though it was a pin, but after talking to a few of the local marine places now convinced it is a broken bolt. My thought is, is there anyway to disconnect the linkage elsewhere to replace the water pump, or am I stuck trying to figure out how to get this bolt out? And if so, easiest way to go about it? There are no straight shots to it, actually thinking the easiest way will be to unbolt the motor from the case and pull it up to try and get access to it... Thoughts?
