shift shaft leak
Benny1963
have been getting a little water in lower .
pressured it up today and its bubbling from my shift shaft seal
1983 evinrude 150 ,the diagram on evinrude only shows a shift shaft cover gasket , and and o ring underneath is that all there is there to leak
looks easy enough .if any one knows what else could leak there
or any info let me know something
thank you all
Benny1963
Re: shift shaft leak
help me guys i just need to know if the oring under the shift shaft houseing
is the only thing that seals the shift shaft rod ,other than the gasket for the houseing
thanks
Benny1963
bump trying to keep tthis thread alive .
but will repost when someone comes on that knows the larger gear cases
ezeke
Except for the gasket on the cover, the o-ring is the seal.
If you take the cover off, it is fairly easy to change the seal. Just use a small awl or a sail needle to get the old o-ring out. Then a drop of oil and a couple of small dowels to put the new one in. A drop of oil on the new one, bend it in half and start it in then hit it from both ends with the dowels to force it into place.
While you have the cover off you can check the shaft to get it good and clean and make sure that it is smooth so it won't tear up your new o-ring. I usually grease the shaft with a little Triple Guard.
The newer gearcases have two o-rings for a better seal.
Benny1963
thanks ezeke thats what i was hopeing have had a little intrusion
and was going to get it resealed by the local boat guy hes pretty
good and fair money wize ,but pressured it up and saw small leak at shaft
thanks for the help my manual is vague in this motor its a clymer
thank you ,
Benny1963
thank you ,
