Hi, I don't really know much about boat engines so here goes!!
My outboard is a J25 BAL CTE & can't find any information on it anywhere.
I was wondering how to put gear oil in it, the reason I ask is because when I got the engine about 3 weeks ago it went in to gear fine, running or not running. I took the boat out 2 days ago and when I got home and hosed everything down went to run the engine in the bucket to clear the salt water, I went to put the gear lever on the motor in neutral and it was stuck in forward so I couldn't pull start it. I pushed the lever back with a bit of force in to neutral but it wouldn't stay and kept pinging back to forward so I got my mate to hold it in neutral while I flushed it and when I did that the prop was spinning so it was still stuck in gear.
After a few hours, I went back and tried to shift it and it was easier but it was still stuck forward no matter where the lever was positioned, the lever is not slipping or anything because everything was still nice and tight as it should be so I am totally confused!
I had a look at it this morning and after a couple of shifts with out it running, everything works as it should and in neutral the prop spins freely but not 100% freely. It's definately not in gear or even close to being in gear because nothing is grinding.
Any help or diagnosis would be greatly appreaciated.
Thanks for reading
Thanks for reading
