5hp carb diagram
gins331
Can any body tell where I can find a diagram for mid 50"s 5hp johnson, got this motor yesterday cant even find the list # on it anywhere to find out what year it is, all I know its green and the tank is on topp, the carb is off and in pieces need to know if I have all of it there and how it goes back together has spark, I would put a pic of it but not sure how to download here.Thanks for any help anyone can give Brian
tashasdaddy
Re: 5hp carb diagram
look on the transom bracket above the transom clamps for a plate. or the freeze plug on the block for numbers.
gins331
I found # stamped on side of motor tn-28 1952-53, have any good sites where I can find carb pics with complete part listing?
CATransplant
Go over to www.aomci.org and post your question in the Ask A Member section. Those folks are really good about posting stuff from the repair manuals for the older outboards. I'll bet someone helps you right out.
samo_ott
It's hard to get parts for those engines. I have 3 of em sitting in the shed.
gins331
Thanks for the info guys, Ive had a 3,6,15 hp old timers and found parts pretty easy Im hoping the same for this one
F_R
There is a guy at aomci making reproduction primer cups. That and the float are about the only items normally needed. And a Mercury float will work.
gins331
Just post on aomci hopefully someone can help thanks again
samo_ott
Nope. I have 3's, 5.5's, 10's 18's etc and the parts for them are easy to get. The 5's and the 2.5's are not.
