22E6441
Thread starter- Joined
- May 29, 2008
- 376
Hi Folks,
This is my first post here, and probably won't be the last. I just bought and older 14' fg runabout with a 1969 Chrysler 35 hp motor. It runs good with lots of new parts installed etc.
Anyway, there's barely a foot of clearance between the skeg and road when the motor is in the down position, and there is no hydraulic powered fancy schmancy tilt and trim on this motor. It's an older boat too, and I want to avoid unnecessary stress on the transom while getting a bit more clearance from the road too.
So, I went into a local marina and asked about these transom saver things. The guy at the counter told me I was crazy for even considering it, as they are only meant for motors with power tilt and trim.
I've read a lot of different posts here about transom savers, but the following question is not answered clearly:
Can I use a transom saver safely with an old motor that does not have power tilt and trim?
Thanks!
Pat
Thanks!
Pat
