frozenokie
Thread starter- Joined
- Feb 4, 2008
- 309
1986 Mercury 115 Inline 6 burns way too rich. I put in new carb kits in each carb and used my shop manual to reset the needle valves/floats. Before I did the carb kits, I couldn't even keep it at an idle. Now, it idles for a few seconds until it loads up with too much fuel. Also bogs just a little out of the hole unless you "feather" the throttle then runs awesome until it loads up after about 10 minutes at WOT, but not in between WOT and idle. Are the floats set wrong (too high or low)?
Also - new fuel pump, fuel bulb, and plugs.
In addition - I'm only getting 4400 RPM with the correct prop (13x19) per the prop shop technician. Could the rich running cause that too?
