Wrong Gasket????
FreeBeeTony
The gasket between my manifold and riser "broke-through"........alowing raw water to enter the fresh water sid of my FWC system.......this was my problem......not a bad heat exchanger!!!!!
When I built the engine (Rapido Vortec) I replaced the manifolds/risers with a GLM kit I purchased from ebasicpower. When ordering online they ask you if you have a FWC system and they sen you a different "block-off" gasket. The gasket below in an Osco p/n......
http://bpi.ebasicpower.com/pc/OSC8503-GB//Riser+Gasket,+Blank+for+Mercruiser
This is just a "paper" gasket, didn't seem right when I put it together put I used it anyway..........apparently it got water logged and broke down.....this is what I am summizing......what a mistake!! I could have blown my new engine!
I will post a pic tomorrow...........this stinks.
I now know the Merc P/N is 27-860231..........I called GLM and this is what they gave me.
Don S
Re: Wrong Gasket????
Still the wrong PN Tony, have a look at this 99 service bulletin.
http://www.boatfix.com/merc/Bullet/99/99_10.pdf
The block off gasket has a SS plate between the graphite coated surfaces. Much better setup that the cheap aftermarket paper.
The new PN (since Merc changed numbering systems a year ago) is now 8637251
FreeBeeTony
I can't believe they (ebasic) supplied the paper crap...........could have blown my engine!!
Thanks for the info Don...........
Guess I will be turning wrenches again this w/e!!!!
Don S
OEM Merc doesn't use a seperate plate, the gasket has one made into it.
FreeBeeTony
That's what I am getting this afternoon............
This could have been a costly mistake!
Ayuh,..... Tony,
Did you catch the thread I posted a couple months ago about how Unflat My GLMs were,..??
Search threads started by Me,+ have a Look
You might want to drag a Flat File accross the gasket surfaces of your's,+ See if your's are Flat Enough......
FreeBeeTony
Just finished installing the new (correct) gaskets..........
I did drag a file across the surfaces to make sure!
Everything seems back to normal...............feel like I dodged a bullet.
Now back to completing breakin...........
Don S
Yea, sounds like you dodged a big one.
Good luck the rest of the season.
FreeBeeTony
Yes Don..........I am quite relieved.
The new gaskets are defifintly better than the paper...........but I forgot about the stainless steel plate............
Just glad I didn't loose the engine...........
