59' 35hp johnson sea horse. please help!
JamFavata
I've recently bought a boat with a 1959 35hp johnson/evinrude(?) seahorse motor on it. this is my first boat and even though i'm an engine mechanic by trade, i have no idea how to work on a boat motor. while inspecting the motor i discovered that the main wire harness that connects to the motor has some corroded and broken wires in it. is there any place that i can order a new wire harness and possibly a service and repair manual for this motor. any help would be much appreciated. thank you
larky
Re: 59' 35hp johnson sea horse. please help!
as far as the manual you can get the factory one at ken cook co.
link here http://www.outboardbooks.com/
and for the wiring harness. you might want to strap yourself to your chair for this one! second one down the page
link here http://www.nymarine.ca/wiringharness.htm
good luck with your motor. if ya have any more questions, don't be shy. many helpful people here.
tashasdaddy
you can do your own harness for much less money. i did.
tnltracy
Agreed. I ran my own due to PO cutting most of the wires off. Used standard wire protection sleeve, but darn, that's a pretty harness there on nymarine :)!
JB
You can get the factory Manual here. move up the page and click on "Johnson Manuals".
asdasc
That is a good tidbit of info! Did you happen to take any pictures of how you did it? I will need to look at the connector again and see if it can be taken apart and reassembled with new wires.
Thanks for the tip!
