I have a 1985 mercruiser 260 chevy v8 in a bja force 220 I purchased the motor as a used unit that was in good shape however after recieving the engine I was surprised to find that the motor was actualy a almost new engine that had very few hours if any on it and it apears to be a factory repower unit as upon close inspection none of the bolts or hardware have had the factory paint cracked off and looking into the valve covers the rockers and pushrods are still brand new looking and the oil I drained out also looked brand new. The only thing that doesnt look new is the distributor. After installing the motor with fresh oil ,oil filter, fresh fuel ,fuel filter both in the carb and the fuel water seperator, and cmplete flush of the fuel tank I took the boat out for a test the acceleration was poor at best and it will only reach a max rpm of 3600 at 30 mph the boat just wont get on plane I did check and the secondaries on the rochester 4 barrel are opening up as they should when you go to wot but it just wont go I have checked timing thats correct other than the lack of power the moter run seemingly well I put about 5hrs on it over the last weekend and it idled started well I have a 14.5x16 4blade prop.
