lenniefoug
Thread starter- Joined
- May 26, 2008
- 13
I have a 1994 evinrude 88 special. For the most part it has never been a problem and in the scope of things has very low hours on the motor. I recently started it up for the first time this year and after 15 or 20 minutes of running I noticed what sounded like a bad bearing noise I shut it down and turned the flywheel (not sure if that is the right terminology) on the top of the engine. It felt tight with no wobble. I also could hear the compression from each cylinder as I turned it. Today I started it again and the same noise was there. Suddenly after 5 minutes the engine shut down and when I tried to restart it wouldn't turn over at all. I then went up to manually turn it again and this time the flywheel wouldn't budge. I let it sit a few hours and I can now move it but with greaqt difficulty and it seems to want to stick before making a full revolution. So my question to the group..any ideas on what happened. I am not an expert motor guy but do have some basic skills. I would appreciate any advice regarding what the issue might be
Thanks for your help
