New member but been reading for a while!..Problem..got a 1988 30' cruisers..twin 350 mercs, fresh water, raw water (lake water) cooled. New impeller, new 140 degree thermostat, oils clean and not milky. At idle port motor gets hot. Goes up to about 180 deg. If i give it throttle temp will go back down but climb again. If I put it in gear, temp really climbs and I shut it down as it nears 200 deg. so I don't damage motor. The mechanic who installed impeller was good enuf to come and make sure I had good water pressure from the drive (alpha 1) to the thermostat housing. Where do I go from here?? Guessing risers and manifolds but how do I flush them or check their not obstructed other than what I might see thats obvious?..Then where do I look from there?...Thanks for any help
