fisherforlife
Thread starter- Joined
- May 23, 2008
- 2
I have a 60 hp Mercury 2-stroke that got stuck in the mud in shallow water. After after moving to deeper water the engine was restarted but after 30 secs was not pumping water still. The engine shut off itself about the time I reached for the ignition to shut it off. I never left idle position after restarting and figured it was an engine stall. However, the engine will not turn a full 360 degrees now. It turns roughly 340 degrees and stops. I removed the spark plugs and all 3 pistons move up and down freely when spinning the flywheel by hand, but it stops in rotation as if something is hitting. At the dock I got lots of suggestions from other boaters. A few being that there is a safety switch that locks the engine. I have never heard of this before now. Do I have major engine problems? Any suggestions or advice would be appreciated. Thank You.
