Doug Redinger
- May 22, 2005
- 73
I have a 1963 Mercury 850 inline six ( 90 cu. in. ) which I have modified to make it like a Merc 1000. I installed the exhaust baffle out of an old Merc 1000 and upgraded the carbs to the KC1A carbs also from an old Merc 1000. My question is this. Are the factory carburetor jetting tables set on the rich side? I have heard in the past that some manufactures set the carb rich to avoid a lean condition and possible engine meltdown. Most of my boating is at 5000 ft. in elevation or higher and I am trying to get the carb jetting dialed in. I currently am running (.069) jets which the factory spec book lists for sea level to 4000 ft. The factory spec book lists (.067) jets for 4000-7000 ft. Which would be about right for my elevation. I don't have the (.067) jets but I do have a set of (.064) jets. I figure if the tables are set overly rich anyway, how risky would it be to run the (.064) jets? You old Merc Guru's have any thoughts on this?
