What prop pitch/material are you running on your Lowe?
hunter066
Re: What prop pitch/material are you running on your Lowe?
I have 2008 1860vtc roghneck with a 90 4stroke suzuki on it. I have a titan ss 13 7/8x19 prop. it runs geat 38 mph at wot 5700rpm. i would like to get a little more sppe and take my wot down to 5500rpm or a little less.
bob johnson
I have a 2008 2070 VTC Ultra Roughneck and have floatation pods and a jack plate and have 2 9 gallon gas tanks up front, i have also removed the rear decking and moved the CC forward... I have side benches in the back to hold my level floatation foam..
i am running a 95 Ocean Pro 115 2 stroke.
I am currently running a SS 13.75 X 15 prop. no gear or load the WOT is 6200rpm's . Once loaded for intended use the rpms drop down to 5800, which is right were i want it... with a top speed loaded of only about 34-35 mph...
unloaded the Top speed is 39 mph.
I have used a factory OMC 14 X 17 aluminum prop and it only gave me 5300 rpms at 38 MPH unloaded.
bob
bob johnson
used the SS prop all winter in duck season and hit a few rocks...bent my prop shaft and ruined the seal, got a lot of water in the LU..
Now i beliebve there is NO upside to a SS prop if you dont run out in the wide open deep ocean!!!
5 aluminum props are cheaper than one SS prop and a bent prop shaft!!
good boating
bob
Irv964
good boating
bob
Sorry to hear that Bob!
That is also one reason why I decided to go with a Turning Point prop, it was way cheaper but I believe it gave me SS performance just the same.
Not sure if you have read this review but I highly recommend them.
http://forums.iboats.com/showthread.php?t=269778&highlight=review+turning+point+props
bryonthefly
BoatNoobie
Just picked up a new to me boat last month. 05 FM165 with a 05 Merc 60 4-stroke came equiped with a 17pitch prop. I believe it's 10". I forgot the exact model #.
At WOT, RPM were low to mid 4K. Max speed was about 26-27MPH GPS. I did hit 30 MPH somehow. I couldnt duplicate it. Must have been a fluke of some kind with the water being smooth or the wind behind me.
Anyways, just received a Black Max 10 5/8 x 12 P prop. Will see how this goes.
bryonthefly
I'll bet that 12p wakes it up. Whats the gear ratio on that lower unit?
BoatNoobie
I have no idea. Are there different versions?
It's a 2005 Mercury 60ELPTEFI
Serial # 1B1444XX
PS, the "X" are actually numbers, but I assigned it with a letter due to privacy issues.
Tiggyboot
I get 34mph on the gps and speedo by myself with a 12P prop with my fm165 with a 60hp 4S, 6200 rpm. Almost hit the rev limitter. With three adults, I get about 32mph and 6000rpm.
bob johnson
once at WOT, playing with the trim can increase speed ...you actually trim OUT...
bob
bryonthefly
Since its not a Bigfoot model, Im pretty sure its a 183:1 final drive. You should get very good performance with the 12 or 13 pitch depending on your load. Good luck, let us know how that works out for ya.
BoatNoobie
Just had my 1st outting with the new prop. WOW it made a HUGE difference. Holeshot is much quicker. Top end, I'm hitting 31.6 MPG GPS. RPM is right at 5900 on console.
Happy camper. :cool:
PS, I'm not 100% convinced my motor is the standard version. I may have a BigFoot. From all the stickers, it should be a standard. But when I look in the manual, it shows the BigFoot version having 2 vent holes for the lower unit and 1 vent for the regular version. On my lower unit, I have 2 vent holes..... :confused:
bryonthefly
Im pretty sure thats the standard 13 tooth spline lower unit. Glad that prop worked out for ya.
RicMic
I have a 17' Roughneck and a 50 Merc 2 stroke, I haven't really got the motor broken in yet, with a light load its turning 5600rpms with the stock
10 3/8"X 14" aluminum prop. The max speed on the gps was just over 34mph.
Once I have a better feel for what its going to do with a normal load and better air temps(it was in the upper 90's). Based on what I was hearing, I thought I would have to go with a 13" or maybe even a 12" pitch prop, but it dosn't look that way. Now I am considering a 14" Merc Trophy Sport.
BoatNoobie
I would like to report, in perfect water conditions, where it is smooth as glass. I was able to hit 34.3 MPH on GPS. :eek:
I forgot to look at my RPM to see where it was though.
It was with 2 adults with full fishing gear and half tank of gas.
The thing about the trim though. I get on plane pretty quick with the motor all the way down.
When I'm on plane, I trim up to try and improve top speed. Well, I barely have to adjust for this. I literally tap the button once, maybe twice to find what I believe is optimal speed. Otherwise, the prop/motor has that weird sound like it's not "normal" to me, if I trim up too much.
Am I not trimming correctly? I would think I would have to trim a lot higher?
RicMic
Thats identical to what I have found, I can continue to trim the motor up until it sucks air and gain nothing. I believe it varies with the hull style, size of motor and prop.
