evinrude switch not working
BAMABOAT
My 40 hp evinrude outboard's switch is not working. I had to replace the switch because I lost the keys. I wired the switch per instructions.....What am I missing. This switch was a little different than my old one as one of the "m" terminals is made to screw down into it instead of just screwing it into side. I am able to make the starter engage by jumping it....so it has to be the switch. HELP !!!
JB
Re: evinrude switch not working
Howdy BAMA.
Welcome to iboats. :)
I take it you are talking about the ignition/starter switch.
Put the original back in and copy down the numbers on the key plate. Take them to your JohnnyRude dealer and he can provide you a new key.
F_R
Well it doesn't "have" to be the switch. Use a piece of wire to jump from the battery wire terminal to the white wire S terminal (at the switch). If it cranks then, it might be the switch. If hot-wiring from battery to white wire doesn't make it crank, there is some thing wrong somewhere else. Probably the starting safety switch. What year 40hp??
BAMABOAT
mmm Key plate ??? ok give me a hint.
