98 40 horse eveinrude running on one cylinder
chopper72
Its getting spark. What are some likely culprits? Is there a good manual that a mechanical newbie can follow?
samo_ott
Re: 98 40 horse eveinrude running on one cylinder
If it's getting spark on both cylinders how do you know it's running on one? Did you do a compression test? Is it a single or double carb?
Solittle
Get the factory service and parts manuals. They are easy to follow even for the average driveway wrench.
chopper72
It is vibrating like crazy and has low power. I concluded that it is running on one cylinder.
tashasdaddy
check your propeller, is it damaged. does it shake in neutral? you dealer will get you a factory manual.
