dvan1901
- Mar 26, 2006
- 503
I'm getting ready to mount a transducer to my transom and had a couple questions. First, I'm planning on using a mounting plate; can I just 5200 this to the transom without screwing it in? Second, I have a catameran style hull with a Bravo III drive and I was thinking of mounting the transducer just to the right of the middle drain plug (see first picture):
From this picture, you might think the spot to the right, where the hull goes up and levels off, would be best, but if you look in the second picture, it is a slightly curved surface and a steeper angle:
This part of the hull is always in the water, but i'm wondering if the counter rotating props will cause problems in this location.
