1984 Force 85 horsepower impeller or impeller kit?
ck85abc3
Frank Acampora
Re: 1984 Force 85 horsepower impeller or impeller kit?
You need the 18-0415. that is the picture at the top. That is for the one piece lower unit and it is installed UNDER the stainless plate.
The other gasket is for the earlier (before 1979) two piece lower unit.
All you need is the impeller and the one gasket unless the seal on top of the pump housing is totally destroyed. (not very likely)
See the sticky thread on the page top. It explains pump housing condition and whether you need one.
ck85abc3
Thanks
