like I said, lets try to keep this on the forum.
the CCS system is rather quirky. below about 800 it runs on all 6,from about 800-1200 on 5, from about 1200 -1800 on 4.
sometimes it gets jiggy.
we need to know O2 sensor output voltage, TPS input reference voltage at TPS voltage output at idle.
did you send the injectors out for cleaning when you did the rebuild?
did you try to find out why the last piston failed?
a failed piston is a symptom of a problem, not the problem.
Answer: Ok I will check O2 Volt, TPS Volt and report back here. I didn't touch the injectors, I will look into that also. I understand what you mean about the symptom not a problem. I assumed that Water had caused the piston failure. The previous owner had used the wrong fuel cap and water was getting in the tank. The engine cut out from 4200 rpm 3 times when I took the boat out in choppy conditions. When I checked what was causing it I saw all the filters full of water (the Racor Fuel Water Separator and the engine filter) I emptied the water and headed back. Next time I went out after only 5 minutes on plane I heard the engine failure from the piston. Was I wrong in the assumption??
