7 pin transducer on my boat , What meter do I need?
Icurious1
Hello:
I have a 7 pin transducer on the bottom of my boat. I was wanting to know if any one knows what kind of a meter goes with it?? If I remove it that just makes two more hole to fill!!
Larry
Silvertip
Re: 7 pin transducer on my boat , What meter do I need?
Meter?????? Care to explain??
Icurious1
Sorry I should have said depth finder, fish finder.. that takes a 7 pin connector..?
Larry
Silvertip
Not knowing who made the transducer we have no idea what locator you need. These plugs are not universal and neither are the transducers except in the case of Eagle/Lowrance lines. 7 Pins is only one part of the equation. Shape of the plug determines what it plugs into. Go to Cabelas, Bass Pro, or any store that sells locators and look at the transducers and plugs. When you find a match, go to e-bay for the head unit. Or buy an entire unit and simply replace the transducer with the proper one. Seal the two holes and move on with your life.
Icurious1
OK...
I have enough stuff to be working on. I will be removing the old transducer and sealing more holes!
Thanks for your time:
Larry
John_S
Post a pic of transducer and the end connector for head unit. Someone may recognize it. If connector end looks like a house (with flat top), it may be a Humminbird 3D transducer.
