mudweiser
- Jun 21, 2007
- 115
Bought a Ranger with a 1977 Johnson v-4 115. Cleaned the carbs, replaced with carb kit. Ran ok. First trip out, it dropped a cylinder. Replaced the coil, still no spark in cyl #3. Replaced the power pak and it ran good on the hose. Took it out to the lake and it ran strong for about 10 minutes. Then it would drop a cylinder out of the hole, some times it would fire, sometimes it would not. I noticed the Tach was not working so i replaced the rectifier. Now thinking it was a timer base or stator, i replaced those also. Still has no spark in cyl #3. Switch the coils, and cyl #3 still has no spark and the problem does not follow the coil. I suppose i have another bad power pak. The powerpak was a new Sierra PowerPak and it only worked for about 10minutes. What would cause these to fail? I can't keep replacing them, pretty spendy. But i have to get it runing good. Any idea what keeps knocking them out?
