Big Puzzle..please Help!!!
rquint04
I have a 1998 225hp ox66 SWSII, Shortly after I got the boat the engine made a hole in a piston so I replaced the piston, all rings, thermostats and gaskets and the machine shop installed a new cillinder sleeve. After restarting I replaced the water pump, o2 sensor, VTS filter, spark plug caps, engine filter, fuel water separator, spark plugs, the three low pressure pumps, and messured high pressure fuel at 35psi constant. the engine has a very rough idle and rough running below 3000 rpm. On accelaration it stumbles until around 2900-3100 rpm when it jumps to 3400 rpm and seems to run fine at high rpms. Also the engine surges 200 rpms up and down at around 3600 rpm in rough seas. The engine wasn't reaching 5500 rpm only around 5200-5300 rpms so I used a smaller prop and then the engine surges rapidly at around 5200 rpms. Any suggestions??
birdbrain
Re: Big Puzzle..please Help!!!
Not the expert here so let the others confirm. The obvious thing I see is that you only made it as far as the VST. Check the screen at the fuel pressure regulator. There are also screens on the injectors that need service. The pros on this forum generally recommend sending the injectors to an injector shop for flow analysis. If that does not do it, get out the fuel pressure guage and look for air leaks in the fuel system.
rquint04
had not heard about that, I will look into it and post again.
Thanks for posting
rquint04
I changed the screen in the fuel press regulator, the injectors were serviced and screens changed. I am still having problems. thanks for any help
