two wire trim swap w/three wire
topdogeye
can this be pulled off two wire blue and green in its place three wire trim blue, green and black on a 89' 60 hrs replacement from an old 75 hrs. please help if you can.
Gary H NC
Re: two wire trim swap w/three wire
I think it can be done.Ezeke or HighTrim will probably have advice..Hang in there.
HighTrim
It can be done, but can we ask why you would like to go to the 3 wire setup?
It is usually the other way around ;)
Dhadley
We used to do it all the time on the race boats. We found a 3 wire that was much faster. All you have to do is cut the "communication" wire between the two relays.
topdogeye
the trim motor on the 89' rusted through got water in the system someone gave me an old 75 hrs how do I go about wireing the older one to the newer controls?
HighTrim
Here is a visual to what Dhadley was saying. The first diagram is your current wiring, the second is how to modify it for a 2 wire motor. Let me know if you have any other questions. Good luck.
topdogeye
are the relays in the controls because I do have the older controls and can install them if I have to. I see the diagram but don't fully understand it when I tried to do it all I did was conect green with green and blue with blue it went up but not down.
topdogeye
I would like to use my current controls if you can explain in a language I can understand I'm a carpenter I understand wood not wires. I really apreciate yall's help so far thanks Jon.
HighTrim
Your remote control is irrelevant, and can be used. Here is a better picture of your current set up, before the modification you want to do.
Simply cut and disconnect the 2 ground wires, and ground the black wire from the trim motor to ground, as per the first set of diagrams provided. Now when there is no power to the relay, there is no connection, and when there is power, you are getting 12V, which will either raise or lower your motor, depending on the button being activated. In my second original diagram, imagine that the 3 wires coming up from the bottom of the page are coming from the trim motor.
topdogeye
thank you for your help man what I will try to do is check the old controls to see if they work if they do I will just use them if they dont I will swap the newer ones for those if I have any problems I will definately get back to yall. Thank you very much Jon D. in N.O.
HighTrim
What year are we talking about?
topdogeye
I hooked up the old relay box to the trim it works. Well there is a delay between going up and down if I try to go up or down suddenly is that normal? The motor still runs while I have the switch depressed it takes a few seconds till it goes up or down but If I'm running I would need instant transfer. Maybe the oil is low? If so where do I add new oil to the unit. Thanks Jon 89' motor putting on around 80'or so trim.
HighTrim
Im glad it worked for you.
There will be a large slotted screw in the front of the oil resevoir. First cycle the tilt fully out, top up the oil, cycle 5 to 6 times, bleeding the air from the system to the fully trimmed out position, re fill, cycle 5 to 6 times. Continue until full.
topdogeye
Is the delay caused by a lack of oil? Because the motor is off of the boat rite now and if it is I will put it back on so I can get it ready and fill the oil back up.
HighTrim
It is possible.
Also possible that there is a clogged passageway or internal valve, air in the system, etc...
Start with topping up the oil and bleeding the air.
Let us know what you find.
HighTrim
Also, does the delay happen when going from trim in to trim out, or when going from trim out to trim in, or both?
topdogeye
one other thing I have a good tac that I pulled off of the boat the 75 hrs came off of is the setting on the back of it the same for the 60 hrs or do I have to change it.
HighTrim
The rotary switch will remain the same.
topdogeye
thank you very much High Trim finding this forum is the best thing I have stumbled apon in quite some time for I do all my mechanic work and the books are limited. Thanks again Jon
HighTrim
Not a problem at all, but again, does the delay happen when going from trim in to trim out, or when going from trim out to trim in, or both?
