TD-20 Johnson oil/gas mixture revisited
Grampsmotor
The owners manual to my "new" TD-20 shows 1/2 pint (8 oz) per gal. I've seen it stated here that a 24:1 or 4 oz per gal is the correct mix.
Can anyone clarify why the restated amount of oil? The motor does smoke a fair amount at the 8oz/1gal mix, but I don't want to damage the motor. Have oil mix requirements changed with improved oil technology since '49? ;)
Thanks for any input.
JB
Re: TD-20 Johnson oil/gas mixture revisited
Ahoy, Gramps.
Welcome to iboats. :)
When your engine was built, 1946 to 1949, specially formulated outboard oil was not available. OMC called for a 16:1 mix (8oz/gal) using 30W non-detergent motor oil.
In 1964, when TC-W outboard oil became available, OMC changed the recommended mix to 24:1 using TC-W oil for all OMC engines built before 1964 and 50:1 for 1964 and later engines.
If you want to use 16:1 with 30W motor oil it would do little or no harm, but smoke a lot more and need decarbonizing and plug cleaning more often.
To use TC-W3, the current standard for outboard oil, mix 1 quart oil to 6 gallons gas or 5-1/3oz per gallon.
Grampsmotor
Thanks JB, this helps. 24:1 it is.
F_R
Little typo there, JB? One pint to 6 gallons is 50:1. But of course you know that. Somebody else might get confused.
JB
Thanks, Frank. I fixed it to 1 quart oil to 6 gallons gas.
Sorry about that, Gramps. :(
samo_ott
Of course gramps doesn't know it but he stumbled upon one of the more controversial topics on the forum! :)
