wildmaninal
Thread starter- Joined
- Jul 14, 2007
- 1,897
Some of you may have seen my thread on "to buy or not to buy old mercury". Well I bought the motor for $150 got it home did a compression check and it shows 120 on nearly all cylinders except for the top one which shows 110. I did not have a battery hooked to anything, I just jumped it straight to the starter. I figure that I need a battery hooked to it to have fire but it wouldn't of done any good due to the burnt wire harness.
I seen that one wire was burnt to a crisp then come to find out that the whole wire harness is toast from the side plug in through out the whole motor just about.
With this compression should I try and fix this problem or part her out?
What are the chances of having any good electrical components left out of this?
Is there a way to check these components (rectifier, coils, etc, etc) and what do I need to check them with?
