- May 19, 2001
- 26,107
1995 K 2500 5.7L 4WD
1 ton springs
only 4K miles on engine and transmission 4.10 gears
197K on the truck
9' Plow
It used to have a sander mounted in the bed......
Click the Picture for the other photos You gotta love the VT rust!! The bed is shot over 18" in all the way accross.
The front of the bed needs to be pulled from the cab and straightened..... this truck sits high due to the extra leafs in the rear from a 1 ton
The plan is to rebuild the bed floor with 1/8" steel, paint and re-install the bedliner.
This is what happens when a bedliner is never removed and the truck is used as a plow truck with a sander.
My intention is to shop around for an old sander too so I can mount one when I am done.
Right now it has a few issues.... the 32 Gallon gas tank leaks .... YIKES!!!
The abs light is on I suspect rust on the sensors
1 ton springs
197K on the truck
9' Plow
