Re: automotive oil in 4 stroke outboard
There is zero negative effect from using a non FC-W oil in a four-stroke outboard... FC-W oil has only been out a few years and up until the rating was issued there wasn't a problem with it. Having said that, FC-W oil helps to reduce fuel dilution and foaming....But that wasn't the question. The question was:
"Whats the harm if you use a premium automotive oil of proper viscosity and keep oil changed regularly???"
And the answer is still none.
So then,...what you are saying that if I,for example,were to choose either Merc,Yammie,Honda,Tohatsu,or whatever four stroke outboard I would by
that if I were to go to Wal-Mart and by Valvoline 10W-30 premium conventional automotive oil,it would be okay to use in a four stroke outboard
provided it recommends 10W-30,and I keep the oil changed on a regular basis,
there would be no harm done to the motor? Maybe it's just me,...but I would
feel alot safer using the manufacturer's oil,...especially while the motor is under warranty.
