dripping out
benrock
i had the water pump done last yr , and it was fine now i started her up yesturday and its driping out. can i blow it out could there be bugs in there or is it the thermistats ? thanks
brandonsb22
Re: dripping out
Probably clogged with crud from sitting. Try getting a piece of wire and running it up the tell tale. Maybe that will work. More experience people will reply here soon.
Gary H NC
Re: dripping out
Probably just a clogged hose.Pull the hose off the tell tale and see if it sprays water out of the fitting of the exhaust cover.If so the hose is plugged.
Bugs love that little opening for some reason..:rolleyes:
There should be water coming out if the T-stats are open or closed.
Benny1963
Re: dripping out
yes pull hose as gary said if you then have nothing move on to cooling system
dont run it if its not pumping after you pull hose ,may need pump
bennyb
benrock
Re: dripping out
i blew the hose going to the 90 degree out , but can i blow the 90 degree going into the engine block with out damage ?
