is this the pee hole ?
kskomro
Can someone tell me? I put muffs on no water from these ports, am I doing something wrong? 197? Merc 20hp If I need to replace pump on this one is it a pain, or easy?
rickdb1boat
Re: is this the pee hole ?
Those are the idle relief ports. You may not get any water from them unless the lower unit is submerged in the water. If your pump has not been replaced in the last couple of years or you don't know when it was replaced, then it's time. It is pretty simple to replace the pump if you have a manual handy.
kskomro
Thanks, The previous owner said he replaced it the year before. I put muffs on and didn't get any water from them. This is my second motor I just bought with the same problem, so I hoped I was doing something wrong. The other one is johnson 25, it's a major to replace bacause the power head must come off to access the shift disconnect linkage.
jbjennings
Here is a pic of what your's should look like on idle. A nice steady stream.
JBJ
jbjennings
By the way, looks like your motor is around a '72 model. Really sharp. I have a 9.8 '72 I really like that looks just like your 20hp.
JBJ
kskomro
You guys are great! I was looking at the wrong darn hole. Humm, I'll be testing the new hole today!
j_martin
You might need to evict a mud dauber with a piece of weed whip string.
hope it helps
John
kskomro
Thanks to all of you for your excellent advise. I used the string trimmer line, and a full trash can of water, and EXCELLENT WATER AT LAST !! The advise was so helpfull, and worked well. The marina repair shop should have given me the advise. THANKS SO MUCH !
