Re: Got her out of the garage...nothing.
All of the following is assuming that you can turn the flywheel by hand, that the engine is not locked up.
I've read all of the above 15 posts/replies. I see no mention of you actually removing, cleaning, then reconnecting and tightening all of the related cables pertaining to the starter circuit as advised.
This, the above, is the starting point. Many cables can be tight but dirty due to corrosion etc. They must be removed (all of them), cleaned... and what they connect to cleaned also, then reconnected and tighten securely with either a wrench or pliers.... not ones fingers if wing nuts exist.
This includes the cables at the actual battery terminals, the cable from the battery leading to the starter solenoid, the other battery cable leading to a grounding area on the powerhead, the short cable leading from the starter solenoid to the electric starter, the small black ground wire leading from the starter solenoid to the grounding area at the powerhead, etc.
To test the starter, run known good cables directly from the fully charged battery to the starter.... the red positive cable directly to the starter terminal nut, the black negative cable to any bolt that is retaining the starter. If that cranks the engine, then obviously the starter is okay.
There are two large terminals on the starter solenoid, one on top, one on the bottom. If after cleaning the cables etc as above, you turn the key to start and all you hear is a click.... temporarily connect a cable from the large bottom terminal to the large top terminal to jump the solenoid. If this causes the electric starter to engage, replace the solenoid.
If however, for some reason, a lack of communication exists in this posting somwhere and no click really exists, I would suspect a blown power fuse which would be located in one of the smaller RED wires leading from the starter solenoid. Check it.
EDIT: (04/17/08) 09:42 PM...... In reading further down, it's obvious that a lack of communication does exist (click/no click). Disregard any of what I've had to say.
