Mercury 80 shavings in unit
fishdog4449
Drained gear oil today; I only use Merc high performance and color was the same as when i put it in. however, there were a few metal shavings on the magnet on the end of the plug, none in the oil. is this something to be concerned about? when shifting the motor makes a loud CLUNK, rather than clutch dog rattle. probably due to it swinging a large heavy ss prop. im actually more concerned about the CLUNK than the shavings, non of the johnnyrudes ive run ever made that loud of a noise when shifting
JB
Re: Mercury 80 shavings in unit
The reason there is a magnet on the drain plug is because they expect some fine metal flakes from normal operation, fishdog.
Nothing to worry about.
That "clunk" suggests that your idle speed may be a bit high or you are shifting without idling her all the way down.
bass_assasin
I agree with the previous answer, there will be some normal wear and tear with a few metal flakes on the magnet. If it clunks when you engage it in gear....your idle is too high
fishdog4449
ok, top of list for next time im on the water is lowering the idle.
fishdog4449
i got the idle down to about 500-600rpm. still a huge clunk, very nasty sounding and 30% of the time would die as soon as it went into gear. when i throttle it up it sounds great and runs about 45mph at 5500 rpm. the prop is a 19p SS quicksilver that the previous owner had on it.
im rebuilding the carbs anyway because they haven't been rebuilt since i bought it. but any other ideas?
