BryanStiles
Thread starter- Joined
- Apr 7, 2008
- 3
This weekend I decide to fix my noisy trim. The motor sounded great when trimmed all the way up. When I would trim down the motor it's supposed to change pitch, you know, where it gets to the two cylinders. But mine was making a noise like it needed fluid (I thought), kind of like it my tractor when it needed fluid in the front-end loader. It's hard to describe that sound, but it's like there is air or something in the lines...
So I trimmed the motor all the way up and flipped over the safety lever. I then loosened the fill plug a bit and just before I took it all the way out there was a bit of fluid that came out. I quickly put the fill plug back in and tightened it up.
After that the motor would not raise or lower!!!
I then opened the manual release valve on the side and the motor lowered. Now the motor will not raise or lower. I took the tractor and raised the motor so I could move it back to storage, but it still won't move up and down.
This evening after work I took the tractor and raised and lowered the motor several times with the front end loader, no change really. I raised the motor all the way up and checked the fluid, some came out so I quickly put it back in.
I'm stumped! The manual says that the fill plug can be opened with the motor all the way up, that when you do and fluid comes out that the reservoir is full. Well mine seems full but the motor won't move! What do I do???
