how to transport outboard motor
Cruising
It's my first outboard it's a 10hp. I'll put the boat on my camper but can i
lie the motor down in my truck or does it to stand up.
tonyg11780
Re: how to transport outboard motor
Its fine to lay it down...as long as its not a four stroke. I know that Mercury four strokes will leak oil back into the intake and carb if you lay them down on the wrong side...
Tony
Cruising
Thank's for the help. It's a old 10 hp chrysler that runs great.
Silvertip
You might want to drain the fuel from the carb before you transport it.
Cruising
Do you mean run it dry or is there another way.
tmcalavy
Clamp a piece of wood in the transom clamp to keep it from rolling around and then use a couple of bungees to keep it in place.
tashasdaddy
the also make a receiver hitch for the front of the truck, and an outboard bracket that goes into the receiver. then you can also insert your draw bar, connect the trailer for tight maneuvering the trailer. makes spotting the trailer a breeze.
Cruising
Thanks for all the help everybody.
jspringator
I bought a BigFoot bag for mine. Appears to work well. A medium is big enough for my 25 HP.
JCF350
Lay it on it's side. SHIFTER handle UP!
