Bushleaguer
Thread starter- Joined
- Jun 10, 2002
- 56
After doing a fuel tank replacement in my boat, I fired up the motor and it started up as it does every spring. Problem is that at idle, every 15 seconds or so, the motor "pops". When on the muffs, you see a large puff of smoke out the prop hub when it happens. Sometimes, it coughs so hard, the motor dies. It fires right back up. I would call it a miss I guess.
I put it in a test tank rather than the muffs, and it does the same thing. I tried a decarb and new plugs, still the same thing. Have new Racor seperator filter installed.
Am I looking at some sort of ignition problem here, or a fuel problem?
I have new fuel hoses below deck, but will try new hoses from the bulkhead to the filter and from the filter to the engine with new primer bulb. What else can I check for?
