krisnowicki
Thread starter- Joined
- Jul 11, 2007
- 1,172
I was at the ramp tuning it up after the repower . I set the timing tightened a couple leaking gaskets and all was well. The fourth time I went to start it the nose cone on my starter broke off inside the bellhousing. First, the starter was on very tight was over the 35-40lbs of torque. It was an arco starter. When I got the starter out at the ramp it had chewed two teeth off about 3 teeth apart on my flywheel. I rotated the engine with a socket and inspected the rest of the flywheel and it is fine. So what is the most common cause of a nose cone break? As far as the two teeth how big of a problem will this cause? Any advice is appreciated. Thanks to all your help I am back on the water and it is beautiful... Thanks
