Alarm On 90 Evinrude
Vantoo
Hey guys, I did this about three years ago. I need to check and make sure the overheat alarm is working on my motor. Can someone give me the procedure again please. Thanks, Rick
Silvertip
Re: Alarm On 90 Evinrude
Turn the key to RUN (not start) it should beep to indicate its working. If you want to check the overheat circuit, disconnect the tan wire and ground it (the wire going forward -- not the one from the sender). Again the alarm should sound with the key in run. You can't test the sender except with an ohmmeter. It is simply a temperature sensitive switch so with a cold engine it should read open circuit. If it reads closed circuit, the alarm should sound and with a cold engine, that would indicate the switch is bad. Putting the sender in hot water should cause it to close at its trigger temperature.
Vantoo
the alarm does not sound when the key is turned to the on position. I will disconnect it and see if it sounds when grounded. Thanks, Rick
