shaneburris74
- Mar 21, 2008
- 11
I am not getting spark on half of my cylinders.
a. When I originally discoverd the problem I switched the power packs. The problem moved w/ the power packs so I thought great I know what it is. I bought a USED power pack locally.
b. Installed used power pack. Same problem still exists..no spark on one side..will move with power pack. I assume used power pack is bad. Shop has another one. I take it home....same indications..now I'm really scratching my head. Only one thing to do now.
c. I buy a NEW power pack. Guess what...same problem. Whatever side the NEW power pack is on is where I don't get spark.
d. I have removed the black/yellow kill wires..it still starts with them removed.
e. I spoke to a tech at CDI electronics...they say I should buy an additional power pack and that they always recommend replacing both (convenient for someone who sells power packs). My local mechanics says he's heard it recommended but never required.
d. I removed my known good power pack and only left the new one on to just test it by itself to try to prove/disprove CDI's theory. It gets no spark with only the new power pack installed.
e. Most people I have talked to have told me to start trouble shooting the stator, but haven't I proved both sides of the electical system good by switching my power packs and being able to get spark on either side depending on where the non-new pack is?
I think this is a doozy of a problem because it just doesn't make sense. I am in the Navy and work with electronic weapons systems and everything that I've learned says if you switch a component and the problem moves then that is a faulty component.....that doesn't seem to ring true here.
Please help! My boat is not near as much fun when its sitting in my driveway...Thanks, Shane Burris
