Re: Can I put gt120 carbs on my gt100?
Your motor is already in the sweet spot as far as RPM goes. Adding 6-inches of pitch will HURT your performance, not help. It's akin to going the speed limit, towing a trailer, up hill, in third gear and dropping it into fifth and expecting the maintain your speed... Also, don't guess - remove the prop and read what is stamped on the hub.
I'm not familiar with you boat. Length? Weight? You might gain some speed by adding a jack plate and raising the motor upwards. The addition of extra height MAY allow you to go up to a higher pitch propeller.
- Scott
